Results 1 to 10 of 11
Thread: The m30 oil cooler is gathering together.
    Default The m30 oil cooler is gathering together.
    Funny, I am short 1 friggin' o ring. Went ahead & got the new oil cooler. The one that came with the cannister had the screw in fittings & was generally beat; it'd look ok in Jeff's car.
    erased due to slander
    Renton, WA
    Where did you buy that?
    1992 535i TCD-s2
    Default Nice Martin...what filter housing is that?
    looks like older style
    Default A local e28 guy had the canister.
    I traded some spare parts to Walt for the canister. He got it for his e28 535; turns out there is an extra galley in the later e34's that is not present in the earlier m30b34 block.
    I ordered new lines, hardware & cooler from our good friends at BMA.
    Default Supposedly it is off an e32 735 "euro" (sic) m30.
    Quote Originally Posted by Scott H
    Default Does it have blank M12x1.5 fittings on it
    possibly to install gauge senders? or are the fittings for the oil cooler send and return hoses?
    Default There are these 2 -6mm x 1(?) fittings with the black torx plugs.
    They end in the bottom of the reservoir for the filter. They look to be good access for pressure senders.
    Default hmmmmmm
    I don't believe any mainstream sender will fit that. Most are M10x1.0 and M12x1.5. Got a solution for that coming up soon.
    Default Item 10 look like something?
    Of course, mine aren't tapped for that fitting.
    Default Yeah I've gone over that with Rutkowski
    The ETK diagram gives us false hope. The oil filter housing on most later M30s does not look like that.
  1. ATF cooler leak
    By Blitzkrieg Bob in forum 5 Series BMW
    Last Post: 07-07-2008, 08:51 PM
  2. E34 M5 Oil Cooler
    By BIGJO in forum 5 Series BMW
    Last Post: 11-06-2006, 01:07 PM
  3. M30 Oil Cooler, where would it be?
    By bergie33 in forum 5 Series BMW
    Last Post: 09-27-2005, 12:32 AM
  4. Trans Oil Cooler
    By saj3n in forum 5 Series BMW
    Last Post: 09-13-2005, 05:28 PM
  5. Oil Cooler for e34 M30
    Last Post: 01-28-2005, 09:42 AM
