Results 1 to 10 of 10
Thread: Sealing the thermostat housing, m60 guys
    Jacksonville, NC
    Default Sealing the thermostat housing, m60 guys
    What is everyone using to seal the thermostat housing. The o-ring and plastic housing obviously don't cut it.
    I made a gasket for the thermostat to housing mating surface, plus a new o-ring, but I still have a leak. If I have to take those bolts out again I'm gonna go nuts.
    It is your thermostat housing that is cracked at the seem and leaking. Buy a new one and it will solve your problem. O-ring is all you need.
    Be sure to purchase a metal housing instead of the factory housing that is plastic.
    Jan 2008
    Phoenix
    Quote Originally Posted by glen-sj View Post
    Yes I am in agreement with the other two posters, I just did my water pump and all it takes is the o-ring.
    thats all folks.
    Jacksonville, NC
    I hate plastic parts. I didn't see a crack in it, however it didn't sit flush against the thermostat. That's why I added a gasket to that side. Crap now I have to wait for more parts.
    If it doesn't sit flush then your thermostat is not in the right position.
    the O ring is all you need, maybe it is warped.
    Quote Originally Posted by RX7guy View Post
    Aug 2008
    Pennsylvania
    When a new o-ring is installed, the cover should sit a mm or two away from the head or in this case the water pump. Once its torqued down the o-ring gets squashed thus it seals.
    Sure the O ring was in the right place? Thermostat sits flush against the waterpump flange, then the O ring, then the housing....
  1. Thermostat housing leak m50
    By colo525i in forum 5 Series BMW
    Last Post: 08-04-2009, 05:02 PM
  2. Question on M50 alu thermostat housing gasket
    Last Post: 12-30-2006, 08:46 AM
  3. M60 - metal thermostat housing ?
    By Super90 in forum 5 Series BMW
    Last Post: 02-01-2006, 11:57 AM
  4. 525 aluminium thermostat housing
    Last Post: 12-15-2005, 03:48 AM
  5. M50 Thermostat Housing Assembly HELP
    By Triv in forum 5 Series BMW
    Last Post: 03-21-2005, 10:09 AM
