Hey Pros,
Done a lot of research on your site trying to find the answer. We had multiplee issuess idle problems and such and check engine light. We have lamda code and o2 sensor code.
The car was having an idle problem for awhile and starving for fuel.
Finally one day when accellerating it would shutter starting at 2500 /2800 rpms up to 3000 rpms.
We also had oil in the plugs and a blown gasket.
We replaced the gasket, several coil boots, plugs.
Also new MAF, New fuel pump, new O2 sensor, new fuel filter and I think some other stuff as well.
Got rid of the idle issue and can tell has more power however it still shutters on accelleration once you reach 2500/2800 rpms to 3000 rpm.
It some times acts like it clears out but when you continue to accelerate it goes back into the shuttle.
Often cannot go 65 and if you can get it to clear out it breaks down agan at 75.
Any idea what next? New coils? Could it be the injectors?
Also we clean out the cats too, not more cats.
Let us know.
Denise and Al
Ride safe and ride long!
We replaced the complete coils, boots, spark plugs/seals, and the value gasket again.
Reset the computer still missing when it accelerates.
It idles beautiful so it doesn't appear to be an injector issue.
Just pulled the muffler, still doing it. Do we need to unhook the battery to reset the computer after we took this muffler off. After we replaced the coils, we rest battery and drove it. Will the computer still recognize the fix if it is the muffler?
Anybody out there?
I'm miss my car
Thought I replied to this so if this is a duplicate my apologies. You will know that oil on plugs means worn valve guides or rings/bores. Any blue smoke? Lambda and O2 sensor are the same depending on which side of the Atlantic you live arent they? What fuel pressure have you got when engine off/running? What inlet vacuum have you got? Have you got any codes now?Is your throttle cable adjusted? - even with all the above you should still be able to get more than 75 mph. Are your brakes running hot?
Thanks for responding!! Appreciate it.
I might have phrased that wrong, no oil on plugs!! had oil in plug holes from gasket blown. Fixed that.
No blue smoke. No check engine light so we should should not have codes. We cleared up the Lamda and o2 sensor codes.
This is what we replaced with brand new parts.
Fuel pump
Fuel filter
O2 sensor
Mass Air Flow
6 coils w/ boots
cats
bosch plugs w/seals
valve gasket
pulled muffler off didn't work
Have fuel pressure but we have not tested it with the car off. should we with the new fuel pump installed?
Have not tested the inlet vacum, will do this.
No codes unless one may show without a check engine light on?
Have not checked the throttle cable adjustment. Was perfect but will check that too.
The car runs perfect at idle and light tippin but hard acceration acts like the timing is off.
How do you check the timing on this car? What advances the timing do you know??
Its got brand new brakes and rotors and they are not running hot.
This is intermitent too. You can get it to 75, 80 but goes through the shutter, sometimes clears out sometimes does not. Runs awesome when clears out. But can't get it past 80 shutters evertime at 79.
Still thinking worn value guides or rings and bores?
With the valve cover off, top part of the engine looks awesome.
Thank you for responding anything else you can offer would be great. We'll get those tests done and report back by tomorrow. Please check back for us.
THANK YOU!!!
Have you tried the crank position sensor?
No, not yet, should we?
Got one on the way $47 US. Should have it by Tuesday.
We appreciate all your help guys. It can be so frustrating coming this far with all
we have replacement without it fixing it 100%.
We fixed check engine light. New fuel pump did that after we replaced the MAF and O2 sensor.
Car had a few things going on at onces.
Should drive like a dream again once we fix this shutter.
What is that big pipe or should say bomb that goes before the muffler? We couldn't put that back on yesterday when we pulled the muffler. Some pieces are broken on it.
We will right back with results!
THANKS!!
