Two bulbs light that display. You'll have to remove the cluster of course. A good opportunity to change all bulbs in order to avoid constantly changing them time and again. When one starts to fail, others will likely do the same sooner than later as bulbs tend to have the same average lifespan.
Follow this link : http://www.bmwe34.net/Wiki/tiki-inde...ard+capacitors
It will describe changing the capacitors of the cluster, but also how to change bulbs and lists what bulbs are required.
Lots of fun!
