Results 1 to 10 of 12
Thread: bilstein install question
    Default bilstein install question
    I'm getting front shocks replaced and getting good deal on sport bilstein strut inserts. One of them is missing a threaded ring that secures strut to housing.
    My question is can I reuse the oem ring that's on the car now?
    part #3:
    http://www.realoem.com/bmw/showparts...44&hg=31&fg=10
    Mar 2007
    Liverpool UK
    Quote Originally Posted by nariusb View Post
    part #3:
    When I changed to Bilstiens the collar nuts looked almost identical so I'd say you could reuse it, but I absolutely destroyed my old ones getting it off so you might end up in the situation... Worth getting an new one I'd say...
    1995 XJR: 4.0L S/charged straight 6 Auto
    What... It's not broken??? I can still fix it
    Also while we on this topic. Are there any problems with having sport bilstein strut, which is designed for lowered car, with OEM springs?
    None at all.
    Feb 2007
    Lebanon,TN
    Do you already have the shocks, if not get a pic of the ring so you can call bilstein and get one. My BS where from an m5, and the threaded ring was COMPLETELY different.
    [IMG][/IMG]Real Racers Go Left AND Right
    Nov 2006
    Lincoln, NE
    you may have a bit of a harsh ride as the shorter strut is designed for a shorter spring.
    the oem springs will be "pre loaded" already due to being extra compressed because of the shorter strut.
    89 Mazda MX-6 GT :: 78 Suzuki GS550E :: 90 BMW 535i/5 :: 02 BMW 330i :: 97 Jeep Cherokee Sport
    Jan 2009
    Ann Arbor, MI
    I'd reuse the strut collar if the old one came off cleanly. I can't think of a reason not to. It's not under huge loads in a direction where it's weak, right?
    You'd most likely find that it'd ride more comfortably with a shorter and stiffer spring.
    Apr 2008
    Belgium
    Be sure to drain the oil out of the strut housing...
    New Mexico
    Quote Originally Posted by Mordan View Post
    Now that is funny......
    M20 525/7 Bore: 84.50mm Stroke 81mm CR 8.5:1, blue printed/dyno & custom chip. Boost @ 6.5psi ~246hp @ 5300rpm / torque @ 269ftlbs. @ 4250rpm
  1. Replies: 8
    Last Post: 02-12-2007, 10:17 PM
  2. ok one more damn bilstein question
    Last Post: 01-02-2007, 04:02 PM
  3. Question on Bilstein/H&R setup
    By JAlfredPrufrock in forum 5 Series BMW
    Last Post: 01-12-2005, 01:37 AM
  4. Bilstein Sport Install Questions
    By JR'Z 525 in forum Suspension & Steering
    Last Post: 02-11-2004, 08:45 PM
  5. Bilstein Sport Install Questions
    By JR'Z 525 in forum 5 Series BMW
