Results 1 to 5 of 5
Thread: Help - Radio wiring '89 535i (UK)
    Default Help - Radio wiring '89 535i (UK)
    Can anyone help with this one? Recently bought the above car with an aftermarket head unit fitted and I'm suspicious of the wiring - sound is awful and switching the blower ON turns power to stereo OFF. Also the pre-set memory doesn't work and fade and balance are all out of whack. The car just has 6 speakers and I think they're the standard ones. Unfortunately I can't find a wiring diagram which matches what I appear to have in my car. I need to know which colour wire goes to which speaker. This is the situation at the moment:
    FL
    blue/brown +ve
    blue/black -ve
    FR
    gray/black +ve
    gray/white -ve
    RL
    green/black +ve
    green/? -ve
    RR
    yellow/brown +ve
    yellow/black -ve
    Ground - yellow
    Aerial - white
    +ve - purple
    12V - pale blue
    These are the colours from the dash not from the radio - I assume they're the BMW ones but I've found a couple of links online to circuit diagrams and the colours don't match.
    TIA
    Dan
    Default Bruno's site has this.
    erased due to slander
    Quote Originally Posted by Martin in Bellevue
    mmm yeah, I've seen it, thanks. But unless I'm being very thick, it's not the same as what I have. Differences between Euro and US maybe?
    Ground - yellow
    Aerial - white
    +ve - purple
    12V - pale blue (ignition)
    12V - red ? constant power
    the above should be right. I redid my wiring on my stereo last night -- 92 520i euro spec
    Default maybe you ask the chaps on the U.K. board
    If you are lucky someone lives near you and you have have a look.
    the link
  1. After market radio wiring. Need help
    Last Post: 02-06-2009, 07:44 PM
  2. 1990 E34 Radio Wiring Color Codes
    By Polley in forum 5 Series BMW
    Last Post: 01-15-2009, 01:36 AM
  3. ::.. e34 Radio / Amp Wiring Diagrams
    By Qube in forum 5 Series BMW
    Last Post: 03-19-2006, 06:17 PM
  4. Quick Radio Wiring Question - Power Antenna
    Last Post: 07-01-2005, 12:55 AM
  5. Radio wiring question
    Last Post: 03-30-2004, 10:46 PM
