Hi all,
On a 1995 touring with LAD suspension:
The power steering creates a loud shriek (ie which sounds like like the belt is slipping). I suspect the battery is not charging properly too.
Is this likely to be the tensioner having lost its tension/or just that it should need a new belt?
Perhaps it is a good idea to renew the tensioner at the same time in this case (I don't know when it wa last done), but what does one normally do- change it every other time one fits a new belt?
The LAD works as does the PS, and once warmed up the car drives and sounds ok. The steering seems fine in normal use- except for the noise (and a bit of a shudder when it is cold).
Am wondering what I should do!
Can anyone advice a good course of action?
Also, the online ETK indicates the serpentine belts are teh same on all M50s. Does anyone know if this is true- partcularly for cars fitted with LAD?
Thanks in advance..
common power steering malfuctions
Because of exposure to underhood heat, high fluid temperatures, ozone, fleaxing, abrasion, grease, oil and road salt, power steering hoses should be replaced at least every 5 years.
When checking power steering hoses, watch for symptoms indicating the hose has deteriorated and should be replaced:
-hose is brittle or hard
With age the hose loses its ability to expand anc contract properly, and cracks appear. Exposure to excess heat (which "overcures" the rubber compounds) can cause this.
-hose is soft and spongy
A good sign that the hose has started to deteriorate inside. Oil and grease-soaked hoses are soft when squeezed, and should be replaced.
-exterior is worn
Caused by abeasion and contact with metal parts, thiscan eventually wear a hole in the hose, causing it to burst under pressure.
Remember hat not all power steering hose failures can be spotted by exterior signs. Hose can deteriorate from inside, causing small particles of the tube to flake off and be carried away in the fluid. These small particles can expensive damage to the pump, pump cylinder and other units.
Composite deteriorations are shown in the link on page 14.
Troubleshooting Guide:
Heavy Steering Effort
1. low on power steering fluid
2. loose rack piston
3. restricted fluid passages in gear assembly
4. bent or damaged rack assembly
5. internal fluid leakage in valve assy
6. external fluid leakge at pump
7. incorrect drive belt tension
8. external fluid leakage at hoses
9. incorrect engine idle speed
10. weak pump flow pressure
Hissing noise when parking
1, internal leakage in steering gear
2. steering wheel at end of travel (normal)
3. when turning steering wheel at standstill (normal)
Growl in steering pump
1. excessive pressure in hoses
2. worn cam ring in pump
3. scored thrust plates or rotor in pump
4. scored pressure plates
Swish noise in pump
defective flow control valve
Whine in pump
1. air in power steering fluid
2. low power steering fluid level
3. pressure hose or line contacting other parts
4. mis-aligned hose and line brackets
5. missing or damaged pump cover O-ring
Rattle in steering
1. pressure hose contacting another part
2. loose pitman shaft
3. lost pitman arm
4. loose tie rod ends
5. loose rack and pinion mounts
6. loose steering gear housing bolts
7. loose steering gear adjustments
Car wanders to one side
1. incorrect front wheel allignment
2. unbalanced steering gear valve
3. loose tie rod ends
Steering wheel surges or jerks
1. low power steering fluid level
2. loose pump drive belt
3. weak pump pressure
4. stickingflow control valve
Excessive play in steering wheel
1. air in hydraulic system
2. incorrect steering gear adjustment
3. loose steering gear coupling
4. loose steering shaft universal joint
5. faulty rotary valve
Increased steering effort
1. slipping pump drive belt
2. internal pump leakage
3. low power steering fluid level
4. too low engine idle speed
5. air in hydraulic system
6. weak pump output
7. malfunctioning steering gear
Poor return of steering wheel
1. maladjusted steering wheel
2. dry ball joints or linkage joints
3. binding ball joints or linkage joints
4. incorrect front wheel alignment
5. maladjusted hweel bearings
6. kinked return hoses
7. internal pump leakage
8. contaminated power steering fluid
9. mis-aligned steering gear to steering column
10. tight steering shaft bearings or bushings
11. bent or damaged rack
12. sticking or plugged spool valve
This of course does not all fit for our system, but most of it. >30 pages of education from
http://www.gates.com/ Gates Auto Education
http://www.gates.com/common/download...n/428-7172.pdf
