Results 1 to 4 of 4
Thread: GVWR = Gross Vehicle Weight?
    Unregistered Guest
    Default GVWR = Gross Vehicle Weight?
    My e34 has GVWR 4575. Is my car this heavy? 4575 lbs? A friend told me that this is gross vehicle weight and it includes four 150 lbs occupants (1 driver and 3 passengers). So that means the car's weight is really 3975 lbs?
    Benneton (United Colors of)
    depends on which model it is....I don't think there is an e34 with a gross unladen weight above 3900 lbs. 525-35 is about 3500, spread for tourings, v8s top out below 4000 lbs. that weight refers to the max weight of the car with passengers, payload, fluids, tow loads, et cetera. the m30s-50's-60s can pull about 2000lbs IIRC.
    Quote Originally Posted by Unregistered
    Windy City
    Default Rick L
    GVWR means maximum permissible weight. GVWR 4575 lbs. is your maximum gross weight. I believe E34 525i is around 3495 lbs. curve weight, E34 530i is around 3600 lbs. curve weight, and 540i is around 3800 lbs. curve weight. Curve weight is with full tank and ready to go.
    RICK
    BMW 1995 525i (Alpine White)
    Unregistered Guest
    Default GVWR=Max allowable weight...
    ...the car can weigh safely / it includes the wt of the car, fuel, passengers, cargo etc...
  1. Anyone ever used their 525 as a tow vehicle?
    By ricola in forum 5 Series BMW
    Last Post: 10-02-2006, 11:01 AM
  2. Vehicle shutting off
    By dave1003 in forum 5 Series BMW
    Last Post: 09-10-2006, 06:08 PM
  3. E34 chase vehicle
    By neil_004 in forum 5 Series BMW
    Last Post: 07-12-2006, 05:05 AM
  4. E34 as my work vehicle?
    By mbogosia in forum 5 Series BMW
    Last Post: 01-08-2006, 07:20 PM
  5. The new vehicle in the stable fj-40
    By shortbuss2336 in forum 5 Series BMW
    Last Post: 05-15-2004, 09:57 AM
