Results 1 to 4 of 4
Thread: running rough
    Sep 2006
    Default running rough
    Hey Guys,
    I have not posted in a while because my car has been behaving. This new problem is a bit of a puzzlement.
    Car starts an idles fine, still idles if you put on ac, or put transmission in drive.
    When I touch the gas then it bogs and dies, and it will die sitting at a light.
    I am trying to go through all the tests in Bentleys, I don,t think it is the idle speed control because it seems to idle ok. Buy the way where is this located.
    My throttle switch tests out for resistance, but I dont get th 5v on the correct lead, I get it on the other 2. Could this switch be causing my problem?
    Lastly, Bentleys says my mas should have a hot wire and I cannot see a wire of any sort. Looks more like a flat blade.
    No engine service light on, and I cannot produce any codes with the stomp
    test. My car is a 1993 525it. Thanks, Edward
    Oldham, England
    Its underneath the inlet manifold close to the block
    My throttle switch tests out for resistance, but I dont get th 5v on the correct lead, I get it on the other 2. Could this switch be causing my problem? It pouring with rain or I would check mine for you. But I'm pretty sure mine is the same
    Bentleys says my mas should have a hot wire and I cannot see a wire of any sort. With the air filter box off, you should be able to see up inside the MAS. When you stop the engine running, the wire glows for a few seconds to clean it. That helps you check its not broken:-) Its a very fine wire, probably about as thick as a 5 amp house fuse wire. Yeah I know they dont use them these days but if you are my age you will remember them
    You arent getting any codes so my guess is its a 'physical' thing - maybe low fuel pressure?
    Sep 2006
    Found the problem by doing a search on this site. It was the brown ring of death on the spark plugs. Changed the plugs and the spark plug boots and now it runs fine.
    Thanks, Edward
    Quote Originally Posted by edward View Post
    Thanks, Edward
    For future reference, the 'brown ring of death' was an over-reaction and relatively normal behavior for plugs. You likely replaced a bad coil boot (shorting), which solved the problem.
    Dave
  1. well its back and running rough still :(
    By misfortune in forum 5 Series BMW
    Last Post: 07-17-2007, 09:26 AM
  2. M60 air leak/rough running
    By Sidney Rough-Diamond in forum 5 Series BMW
    Last Post: 05-18-2007, 04:24 PM
  3. E34 540/6-Engine running very rough
    By 540ii in forum 5 Series BMW
    Last Post: 12-14-2006, 11:35 PM
  4. rough running
    By jippijak in forum 5 Series BMW
    Last Post: 02-26-2006, 04:46 PM
  5. Running rough when cold
    By Trevor in forum 5 Series BMW
    Last Post: 12-04-2005, 09:59 PM
