Results 1 to 7 of 7
Thread: Low Battery... or Something Else?
    Jan 2005
    Williamsburg, VA
    Default Low Battery... or Something Else?
    I've got a 1989 535i (225K miles) that's refusing to start. I've run the battery down a few times over the last year or so, and this is different. This morning, the solenoid clicked loudly, I could hear the starter motor running, but the engine refused to turn over. Now, this evening, I just here a light moan from under the hood... no clicking.
    I metered the battery, 9.6 volts. Seems low, but normally I would still hear the starter turning, right? The interior lights fire right up, which is not indicative of a battery problem.
    I just filled with gas a day or two ago, so unless it's bad gas, there's plenty in the tank.
    Other places to check? Starter motor? I know there's a similar thread going on now (Car won't start; suspect fuel problem), am I in the same boat?
    Thanks for any advice!
    Norman
    '89 535i, 225000 miles, family owned... Williamsburg, VA
    Oldham, England
    Quote Originally Posted by ElNormo View Post
    Norman
    Solenoid that sounds like a machine gun is a dead give away for a low battery. 9.6V confirms it. I bet you can jump start it. When you have the question has got to be why is the battery so low?- duff battery or duff alternator?
    Jan 2005
    Williamsburg, VA
    Quote Originally Posted by whiskychaser View Post
    Yeah I guess normally I have a tendency to run it all the way down . My chime is broken, so I often leave the lights on and not notice the idiot-warning on the dash. I'll go hook up the charger tonight and check it in the morning.
    Thanks for the heads up, I'll let you know how it works out.
    Norman
    u need 12V for the ECU, so u better find some electrons and stick em in first
    9.6 volts. that battery is dead as disco.
    Yep... dead... dead and really dead.
    Quote Originally Posted by Ross View Post
  1. Battery FAQ
    Last Post: 07-12-2009, 10:09 PM
  2. How To Get Into An E34 With No Battery
    By E34 Lover in forum 5 Series BMW
    Last Post: 02-23-2008, 08:32 PM
  3. need a battery for the 540... what to buy?!
    Last Post: 04-29-2006, 07:11 PM
  4. battery??
    By PhilipJCaputo in forum 5 Series BMW
    Last Post: 11-22-2004, 01:11 PM
