if you cant get the cable end out from the motor you cant move the seat. If you can you can use a drill to move the position hopefully enough to remove the 2 rear bolts. Once those are out raise the rear bottom of the seat 45% or so and slide the front part back and it should slide out... good luck sounds like a PITA
