Most likely a new assembly. Or just bypass it as you don't really need it.
Coolant level sensor float broken loose. Barrel shaped float with hole in center is loose in the '89 525. CAn this be reattached or do I need a new assy?
coolant level control is important, better buy a new float.
Many cars don't have it and they don't have any problems. If you check the fluids periodically then you'll be fine.
well, you know that you have to check it periodically, but I am sure my wife does not know ;-)
So I am happy that we have all the gimmicks with alarms, then she will tell me.
Those barbs are cheap plastic ****! Both of my barbs broke off last weekend and I got the Coolant Level message and BING every time I start or stop the engine. Probably from years of stewing in the intense Arizona heat - cooked it good.
BMA has them for about $12 (their part # is BMW026980).
Can you replace this without removing the radiator?
I tried real quick to reach it from below but it seemed tight - got hands dirty.
JD
1997 535i V8
