Are you sure it is engine oil? I had a drip that wound up being PS fluid that was from a leaky hose connection with the reservoir.
If you can pull the plastic, then pull it. Then clean everything so you can spot anything new that leaks/drips.
I've got a decent oil leak in the front part of the car and cannot locate it. Any clues? There is a plastic sheild under the front of that car that catches it and it drips from there. There's about a 4" spot on the driveway every morning. Mrs. not happy with the stains.
Any clues?
1952 MG TD
1963 MGB
1967 MGB GT Special
1974 MGB Roadster
1991 Ford Ranger
1997 BMW 528I
2000 Harley Davidson Softail
2004 Ford Expedition
"Uncle" Phil C
2011 Kia Optima EX-P.
Former owner of a 95 525i 5spd. "The GQ" aka A Shark in sheeps clothing
03 R1150RT 6spd. "DaRTth"
00 R1100R 5spd. "LeRoy"
Pop that plastic shield off and clean up the front of the engine. Run it and see where the leak is coming from. That shield is held on by 4 plastic nuts, so its a nobrainer to pull it off. I have a similar leak and came to the conclusion that my oil pan gasket has deteriorated at the front and is now leaking. I sense fun times ahead for me
I'm missing about 6" of gasket at the front where the sump joins the timing chain cover. Used nice blue sealant to fill the gap. Is it pretty? Cant see it and neither can anybody else. And it hasnt lost a drop in over a year. Just have to make sure the surfaces are clean and dry
I had it off when I got it and did not notice the leak from down low but from higher up. Need to scope it out again.
1952 MG TD
1963 MGB
1967 MGB GT Special
1974 MGB Roadster
1991 Ford Ranger
1997 BMW 528I
Howdy Adnan !
I'm doing great thank you....Living in TX now and enjoying the 70/80mph speed limits
Just got back from a 450 mile round trip in the GQ and running 70mph on the back roads when I could and 80mph on Interstate 10, my trip avge MPH was 65.4 MPH and the MPG was 25.9mpg...with the a/c on all the way!
Hope life is good for you.....Hey! A Bimmer is a Bimmer mate...newer design/smaller body or not
Stay fit, well and out of trouble
"Uncle" Phil C
