Originally Posted by
h2oyo
hello and thanks for the info, I replaced my injectors yesterday and while doing the work I removed one of the water temp. connections. Now the temp gauge moves around kind of like the tach. I am going to remove it and and replug it making sure its secure after the motor cools down a bit. My question is if its a good idea to use that electrical gel in the connection. It will keep it water tight and it should keep it clean. I know I use it at work on the machines. What I dont know is if it will help or hurt on the car being lower voltages. Has anyone else done it and is it ok to do.
Johan
