Results 1 to 8 of 8
Thread: Coil pack guts?
    Minneapolis, MN
    Default Coil pack guts?
    Waiting for parts to arrive, I started digging around the rest of the engine bay and found some small, hard yellow drops on two of the coil packs. You can see them in my crappy cell phone pics right where the metal base meets the black pack. Is this glue of some kind or the actual electrolyte whatever leaking out?
    The resistance on all the coil packs tested at 0.8 ohms (which is still in spec). And I don't see any stress cracks or discoloration. I sure wish they'd have stamped dates on these things.
    I know this isn't the greatest picture, but I also found this clear paste inside the boot and on the tops of the spark plugs. Don't recall seeing this in my old M50. Is it some kind of conductive paste perhaps?
    When the coil leaks, it leaks big. It's usually a crusty white substance
    Minneapolis, MN
    Default Thanks.
    OK, good. Just wanted to make sure.
    Quote Originally Posted by wool View Post
    Sep 2007
    Seattle, WA
    And yeah, the grease in the coil boots is a conductive grease.
    Benneton (United Colors of)
    take em out and look at them with a magnifying glass. if you see any hairline cracks (i'd bet money that you do if they are original) you are only prolonging the inevitable.
    Nov 2004
    Split, Croatia
    Quote Originally Posted by ryan roopnarine View Post
    +1
    If/when you decide to replace the coils, go for BREMI again, BOSCH tends to crap out more often.
    If you go Bremi replace the plug boots with Bremi, same with bosch/bosch due to differences in resistance.
    Quote Originally Posted by Interceptor View Post
    +1
    Nov 2004
    Split, Croatia
    If I remember correctly, when you buy BREMI coils from BMA, you get them with boots
    Anyway, differences in resistance are so small it's irrelevant.
  1. New coil pack, but still no spark... M60 engine
    Last Post: 10-27-2010, 10:29 AM
  2. 540 Ignition Coil Pack
    By bmw540 in forum 5 Series BMW
    Last Post: 10-06-2006, 04:13 AM
  3. Replies: 6
    Last Post: 06-14-2006, 07:27 PM
  4. E34 535i MUFFLER GUTS
    Last Post: 04-20-2005, 03:36 PM
  5. what's the best way to test a coil pack? thanks.
    Last Post: 04-13-2004, 08:23 PM
