Results 1 to 4 of 4
Thread: brake booster hose- how special is that?
    Minneapolis, MN
    Default brake booster hose- how special is that?
    Quick question:
    Do I have to replace the hose connecting the engine to the brake booster with a specific kind of hose or can I just go with the generic AutoZone vacuum hose of equivalent diameter?
    It is stronger, stiffer than usual. Regular hose will collapse under such vacuum pressure and give you no brake boost when it fails.
    Minneapolis, MN
    Thanks, Tiger. That is exactly what I needed to know.
    It has several layers. Even when old and brittle, they are usually good. Its a safety item
    Just make sure it is fastended well at both ends, should be good.
  1. squeaky noise at brake pedal- lubriacte the brake booster?
    By werminghausen in forum 5 Series BMW
    Last Post: 06-12-2008, 01:22 PM
  2. OT: brake booster or master cylinder?
    Last Post: 10-14-2007, 08:38 AM
  3. Where is the check valve in the brake booster?
    Last Post: 11-21-2006, 01:42 PM
  4. Vacum hose going to brake booster
    Last Post: 05-21-2006, 05:56 AM
