Results 1 to 10 of 10
Thread: Low speed steering click/clunk
    Chicago
    Default Low speed steering click/clunk
    Whether just pulling out of the driveway or within the first tens of feet after a stop/brake, I can hear a low level clunk under pretty minor steering. No 55-60 shimmy, even with Blizzaks still on. Any guess? Lower control arms done approx 2 yrs ago with pretty low mileage on them.
    'It has been said that politics is the second oldest profession. I have learned that it bears a striking resemblance to the first.' - Ronald Reagan
    could be the swaybar links. i was going to say the balljoint on the lower control arm, what about the bj on the upper control arms?
    Mar 2004
    Did you tighten the big nut on the steering column (that is located above/behind the dash knee panel) - that causes a lot of problems if your front end is pretty new? This is pretty painless and often overlooked.
    07 525i 22K, 07 328xi (41K)
    +1 on sway bar link.
    Jan 2008
    Sweden
    I have the same, and everything up front is brandspanking new! So I´m guessing steering column nut too!
    There is another thing that cause that click/clunk... that is the dogbones on the rear. Cheap dogbones click/clunks like when devoid of grease.
    Sep 2005
    Central Coast, CA
    Quote Originally Posted by tiger View Post
    +2
    http://www.bimmernut.com/forum/image.php?type=sigpic&userid=3314&dateline=1239168  877
    Dunlap Illinois
    Sure sounds like the swaybar links.
    or the notorious nut behind the wheel. My first guess is swaybar links then ball joints. to check the ball joints get the car moving very slowly and jab the brakes, do it in forward and reverse. If there is a clunk its the ball joints (somewhere) if no clunk than most likely sway bar links.
    Chicago
    Thanks gents,
    Will look into all suggestions this weekend.
  1. Steering Wheel Shake (limited speed range)
    By SnakeyesTx in forum 5 Series BMW
    Last Post: 07-14-2006, 12:10 PM
  2. not a clunk more of a click
    By diamond777 in forum 5 Series BMW
    Last Post: 03-26-2006, 06:29 PM
  3. Adaptive 5 speed (E34) clunk
    By LynnSegal in forum 5 Series BMW
    Last Post: 05-11-2004, 04:49 PM
  4. CLICK in steering just off or at center
    By mholbrook in forum 5 Series BMW
    Last Post: 02-23-2004, 01:48 PM
