Results 1 to 10 of 12
Thread: Thrust arms are winning....again :(
    Feb 2007
    Default Thrust arms are winning....again :(
    I had a good go at the front suspension and have hit problems all day! 2 of the 3 bolts for the steering plate were easy but the third is obstructed by the lower arm so I took the lower arm off to get access but then you can't get any leverage because the whole hub assembly moves. Luckily a friend was passing at the time so I got him to hold the wheel hub while I loosened the bolt.
    I made no impression on the thrust arm bolt at all, then I realised that the nut is 22mm but the bolt is 21mm so I need to go and buy the 21. I decided to remove the sway bar to get better access, I managed to loosen the 18mm nut but the two smaller nuts are harder to get to and I need a 15mm socket which I didn't have (15mm and 21mm are the only sizes I don't have). The shops were closed so I have to wait to continue with this.
    So then I moved on to the tie rods. I was going to replace the centre rod anyway and now I've realised I may as well replace the outer tie rods as well (even though only a year old) and removing this will give me more leverage space on the thrust arm bolts. The ball joints with the outer tie rods were simple but the ball joint left of centre ( looking from the front back) on the centre tie rod is very hard, there is no space for the ball joint puller, I removed the protective metal plate above but theres still not enough room to get the puller in there - although I've just been looking at realoem and it looks like this is the joint with the idler arm which I am also going to replace so I might not have to remove it - only bit of good news all day! I haven't had a look at the other ball joint yet (the one with the steering arm I think).
    So I'm still none the wiser about the thrust arm bolts, I have no idea if I am ever going to get these off, I don't know how you guys do it, maybe I'm just too wet! Do you guys undo the bolt or the nut on the thrust arms?
    I'll get the bits I need and try again next weekend, I might have to get some extra help even if its just for encouragement...the memories of trying this last time are flooding back
    Oldham, England
    I'm not sure which bolts you are stuggling with IIRC there are 3 that go up through the plate at the bottom of the strut. To remove the bottom arm you remove nut 15 and bolt 4:
    http://www.bimmernut.com/forum/newre...ote=1&p=333021
    The problem is probably blindingly obvious to everyone else
    Feb 2007
    Quote Originally Posted by whiskychaser View Post
    That is a link to this thread! I think its an experience thing really, if you've done this many times before I guess you would go to town on these nuts more than the inexperienced (if you see what I mean!)
    I've managed to loosen the bolts for the steering plate, the only problem now is centre tie rod situation and the thrust arm bolts. I've just read somewhere that you need to remove the big bolt on the sway bar plate in order to drop the cross member enough to get access to the bolt. Its a shame its gone dark, I'm dying to get out there and give it another go!!
    Oldham, England
    Oops. Said I was having trouble keeping up I meant 15 &4:
    http://www.realoem.com/bmw/showparts...50&hg=31&fg=05
    Mar 2007
    Liverpool UK
    I think I'm with you on the thrust arm pivot bolts... Mine were on tight the first time!
    I'm assuming the set up is the same as mine - I got a ring spanner on the nut and a reasonable breaker bar on a socket on the bolt end and undone from there. You don't evenhave to hold the spanner that way as it will naturally hit the chassis and prevent the nut from moving so you have two hands to push on the bar
    The other end is the balljoint which you'll need to undo and get a balljoint seperator/pickle fork on. I would never attempt this without the scissor type balljoint seperator as it makes life SO much easier! Have a look at this if you get stuck: http://www.bimmernut.com/forum/showthread.php?t=39481
    1995 XJR: 4.0L S/charged straight 6 Auto
    What... It's not broken??? I can still fix it
    Reading, UK
    Quote Originally Posted by e34.535i.sport View Post
    Does the OP have a -good- breaker bar?
    You really need one for work like this, and it -must- be at least a meter long. Helps no end once you're starting to work on bolts 17mm and above...
    Feb 2007
    Quote Originally Posted by Ferret View Post
    I've got a breaker bar, its about 60 cm i think, I can just about get enough clearance under the car to get it to move, any bigger and I don't think I'd have enough clearance. I had to lift one whole side of the car off the ground with a trolley jack to get the jack stands in on their second setting, I don't fancy lifting it any higher!
    I agree though that a breaker bar is a must, I can extend mine with the bar from the trolley jack, this thing is the real deal....
    I also bought this, I thought for £30 I'd give it a go, not expecting ground breaking performance but i figured 200nm would be enough for anything on the car...
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...=STRK:MEWNX:IT
    I've seen the posts about buying a good one to get any success but I can't warrant spending £150 on one, I wouldn't use it enough, I saw some 24v cordless ones but thought I'd give this one a go, it looks too good to be true but they guy has good feedback and has sold a few of these.
    Mar 2007
    Liverpool UK
    For me I find a small breaker good for tight spaces (saves breaking any ratchet mechanisms! ) and if necessary I throw the trusty extendable wheel nut wrench on the end... Does the business!
    Sep 2007
    Michigan
    You need the scissors type ball joint separator. Once you torque it down a bit. you bang on the side of the offending member to get it to come loose. I tried two other kinds, pickle fork and puller looking thing and didn't get either to work. I soaked the nuts in PB Blaster and that helped. Make sure your face isn't anywhere near when that torqued separator comes loose. A good loud bang may occur.
    Quote Originally Posted by leicesterboy15 View Post
    I had to drop the sway bar on mine the first time, there was no room to get a wrench on the nut. After that whenever I would do thrust arms, I ground a wrench so it would just slip into place. I didnt over torque them on assembly so I can get them out with the cheater wrench. It is ground down a LOT and doubt it would hold on my first time.
  1. About to do thrust arms, control arms, and shocks
    By 530iBall in forum 5 Series BMW
    Last Post: 09-24-2007, 12:20 AM
  2. thrust arms or upper control arms
    By gsxr9 in forum 5 Series BMW
    Last Post: 01-25-2007, 11:02 PM
  3. Replacing thrust arms vs. thrust arm bushings
    By JAlfredPrufrock in forum 5 Series BMW
    Last Post: 05-09-2005, 08:08 AM
  4. Replies: 2
    Last Post: 10-29-2004, 09:16 PM
