Originally Posted by
whiskychaser
This sounds very much like what I have got. I have all the original keys and the only thing in the 'master' is a bulb for a torch. There is a slight complication in that mine isnt a UK market car - its S African
I didnt think it had an alarm so did a little test. I double locked it with the driver's window open then reached in and tried to start it - it wouldnt start and set the alarm off
Yep - thats mine as well.
One and only key I received with the car has the little torch globe only.
And I do have the alarm system - I've set it off accidently a couple of times while trying to sort out the wiring.
It'd be nice to get this sorted out so all the differences are obvious in each model run & market... Now there's a worthy challenge.
Here, here.
This may be totally unrelated, but the dash LED on mine flashes for about 8 seconds before it goes steady and the immobiliser is set. Is it possible that when you double lock and then open immediately it works as the immobiliser circuit hasnt yet come into play?
I haven't noticed that my LED does anything, but then I've never watched it intentionaly. Will do so to test if it does anything and what causes it to.
My alarm wasn't inexpensive - about $279 from memory. It was a United Security System and "supposed" to be made for the BMW. Promised that it would plug into the existing plug under the back seat. I had to send them the VIN to "make sure I got the right one".
But when it arrived, the instructional CD didn't match the alarm unit itself.
I went back to them and they told me that my model couldn't use the plug and I had to install behind the kick panel instead. I accused them of false advertising but got nowhere. Then they sent me a PDF of the correct instructions which still didn't match my cars wire colour codes. (Probably cannot blame them for that in fairness).
But then when I asked for help, they didn't at first give me information relating to the alarm they sent me (eg: told me I needed the extra diodes attachment for the comfort windows while mine already had them installed in their loom inside shrink wrapping) and after that they ignored me despite many plea's for help.
I was too scared to return the unit as I didn't think they'd refund me and thats when I decided to battle it out on my own.
It didn't seem that they knew their own product at all.
The Fobs have the switchblade key which at first I thought I would like, but now realise that I don't - they're big, weighty and awkward in the ignition switch with a bunch of other keys on the same keyring (unavoidable).
My biggest remaining problem is that I can get it to double lock, but it won't then unlock from the double locked condition. Solve that and I'd be okay. Comfort windows would be a nice bonus but I could live without them if necessary.
I'd happily turf this system now and either go OEM or purchase a system that is known to work 100% with my car.
ss2115.
BMW 525i Touring - 1993 (current drive car).
DS23 Citroen Safari - 1974 (restoration and modifications).
Golf MkIII - 1997 (fun car and daughters learn-to-drive car)
