30 k is not much for a fuel filter. I would check the voltage, maybe that is the cause it dies, especially check the fusable link which could have haircracks.
Drove the car from Long Island into Philly early this morning. Ran fine the entire way until I got off the freeway and into local traffic trying to find a parking spot on the street. At one of the first lights, the car bucked a little, likely due to delay in throttle response and then I got a check engine light. At the next traffic light the car stalled. Fired right up and quickly tried to find a parking spot. In the process the car stalled several times, mostly when stopped or coasting, and pretty much started up without a problem immediately.
I replaced my intake gaskets, fuel filters, and fuel pump in Dec 06. I'm not sure why I'm getting this problem so suddenly. I wonder if I can manage to attempt to drive it home tonight, hoping that I won't stall out at highway speeds.
I realize that there is a long list of possible causes for this problem and I haven't had the chance to check any of them. I've put 30k on the car since I replaced parts in winter 06.
One other observation, maybe unrelated. I've been getting a warning for low engine oil, especially after long drives, but the dipstick shows that the level is fine. This message came up again today after one of the stalls.
'94 540I 6spd/205000 miles
Update.
Car cranks, but won't turnover. I didn't have the time or the tools to check the plugs or do any other diagnostics. I suspect that this could be a fuel delivery or TPS sensor problem?
It might be the crank position sensor.
I got my replacement from Checkers. Popped it in and it fired right up.
Ramon
1994 540iA Nikasil EAT Chip
Tampa Bay, Florida USA
Any codes showing up? Check Engine Light?
Here's the old thread:
http://www.bimmernut.com/forum/showt...osition+sensor
It's a pretty easy job. Clean it off by blasting with a can or two of electrical parts cleaner. A really bright light helps.
Ramon
I think it is CPS... unless your alternator is not putting out enough voltage. Check battery voltage.
CPS when cold, should run unless really dead. Splashing cold water on the CPS when engine is hot and engine runs... is sure sign of bad CPS.
I did get a couple check engine light flashes and I will check codes and voltages today. As I was trying to park the car and it was stalling, it did get a little more difficult to turn over on one of the last times I had to restart it. After sitting all day, it didn't even think about starting.
MBXB, you saying I should try to clean the old one, or the new one with electrical parts cleaner?
Tiger, are you saying that the cold water trick isn't worth trying now that the car is cold?
The sensor is located in front of the engine. You can follow the lead as it comes out of the engine cover down to the mounting point.
Chances are it's all encrusted with grime. Oil will mess with electrical signals. It could be something as simple as oil on the contacts.
Either way, it will make the job a lot easier to clean the area. You don't want any dirt on the contacts if you have to replace it. It won't hurt anything to blast it with the electrical parts cleaner. It's plastic friendly and the crap ends up in the catch pan.
Ramon
Today I was able to test a working fuel pump relay. No change. I also measured the resistance between pins 1 and 2 of the CPS sensor and got a reading of 10-15 Mohms. The reading was wandering higher and since I'm already much higher than the 1200 ohms stated in the bentley, I'm assuming that my sensor is borked. I'm going to check fuse 23, 17 and 2, just in case.
I've contacted BMA and the stealer about a new CPS sensor since there are several posts indicating that buying OEM for M60 engines is important. Looks like I'll be out about $140 unless my buddy can get a discount at the dealer. BMA wasn't cheap enough to justify the wait in shipping to the east coast. I'll be sure to clean both the contacts at the plug and also at the sensor with electrical cleaner before I put the new one in though.
Thanks for your help. I'm just hoping its as simple as the CPS sensor otherwise I'm going to have to get it towed.
