Results 1 to 4 of 4
Thread: How hard is it to replace the headlight high beams switch?
    Dec 2006
    Default How hard is it to replace the headlight high beams switch?
    I did a quick search, but couldn't find anything.
    My high beam switch is dead. I still have flash to pass, and the turn signals still work. How hard is this switch to replace?
    Oldham, England
    IIRC the switch has barbs and clicks into a housing in the column frame. On mine you cant part the upper and lower column cowls without removing 2 screws at the top. The problem is you cant see them let alone remove them without taking off the steering wheel. Not an issue for me as I dont have an airbag.
    Dec 2006
    I don't have an airbag either. Is it tough to crack the big nut holding the steering wheel in?
    Oldham, England
    Quote Originally Posted by repenttokyo View Post
    Not at all. It will help if you have the steering locked. Once you have removed the nut and washer you will need to unlock the steering again to allow you to pull the steering wheel up (off). I dont know if its absolutely necessary but I'd make sure the indicator arm is in the mid position when you put the wheel back on. There is a little lug that activates the self cancel and you dont want to break that off the new switch.
    Edit: If yours is like mine, the bas...d screws you cant see go into the lugs on the far right side of part 3:
    http://www.realoem.com/bmw/showparts...93&hg=32&fg=30
  1. High Beams not working
    By Keith W in forum 3 Series BMW
    Last Post: 11-14-2006, 11:08 PM
  2. low beams, high beams
    By pong in forum 5 Series BMW
    Last Post: 09-21-2005, 03:19 PM
  3. High Beams
    By drum2430 in forum 5 Series BMW
    Last Post: 04-08-2005, 06:37 AM
  4. How to replace bulb in the headlight switch?
    By Mario in forum 5 Series BMW
    Last Post: 08-28-2004, 10:26 AM
