Results 1 to 2 of 2
Thread: 92 525i overheating problem
    Default 92 525i overheating problem
    hi all, i'm new to this forum.i'm facing overheating problem with my 92 525i when i stuck in heavy traffic or keep idle for some time.I noticed that when i turn on the ac, it overheats, without ac it runs fine. then i notice that the fan which is mounted on the condensor (auxilery fan) is not moving even when i turn on the ac. is it fan itselt culprit or any thingelse..
    thanks for your advice please
    baton rouge, loserana
    the resister is probably dead on the aux fan, it should come on low with the ac, and when the pressures get high enough it will switch to high. the resister is the little finger sized thing to the lower drivers side of the fan, you can replace just the resister you need to splice it in, i solder them in but you can use good yellow size crimp connectors
  1. overheating problem
    By innes in forum 5 Series BMW
    Last Post: 09-22-2006, 06:28 PM
  2. Overheating problem!!
    By JAK in forum 5 Series BMW
    Last Post: 08-05-2006, 07:57 AM
  3. overheating problem
    By E34maystar in forum 5 Series BMW
    Last Post: 02-01-2006, 01:29 PM
  4. Overheating problem on my 92 525i
    Last Post: 12-20-2004, 01:49 AM
  5. Another overheating problem
    By sah525i in forum 5 Series BMW
    Last Post: 08-29-2004, 07:18 PM
