Results 1 to 10 of 18
Thread: Installing the sword on a RHD vechile?
    Default Installing the sword on a RHD vechile?
    I spoke to a mate today who said he had done it before but it seems the steering linkage is in the way. when I removed it it was very tight on the linkage but I manged to get it out somehow by also pushing the brake pedal.
    Now I can't put it back in??
    Any help guys with RHD cars?
    Oldham, England
    I have an auto and dont have the sword so the 'black box' came out relatively easily. I wouldnt have got the filter in if it hadnt been a two piece because the steering column gets in the way. Sounds like you need an extra pair of hands - or feet - to press the brake and clutch while you jiggle it back in there?
    I have an auto also, no microfilter. The steering column seems in the way, its not the brake pedal that I have to worry about.
    http://picasaweb.google.com/Kristian...61725836140882
    Jan 2007
    Dayton Ohio
    Interesting my sword comes out on the right side but my steering is on the left. Guess that is one of the benefits of having the steering on the left
    Aug 2007
    New Zealand
    I cheated a little and ground a small amount off the end of the heat sink so I could just angle it in. The purists wouldntb approve though!
    Thanks Erich. I read that before but it doesn't help. I tried for over 30 mins and even got my mum to try to no success
    Thanks I dont want to do that but I might have to as a last resort.
    Quote Originally Posted by Grantus View Post
    Australia
    At least you don't have a manual. I had to disconnect the clutch pedal and swing it up out of the way, then remove part of the steering column and also press the brake pedal in. Was a horrible job. You can loosen the two mounting bolts for the hvac box so that you move it just a touch and that helps to get the sword back into the hole. Good luck
    Mahalo from hawaii!
    Jan 2007
    Dayton Ohio
    All so you can have the steering on the wrong side
  1. Anyone looking for a sword
    By nirvana19 in forum 5 Series BMW
    Last Post: 11-04-2007, 02:24 PM
  2. BMW sword
    By xtmsports in forum 5 Series BMW
    Last Post: 10-29-2005, 12:13 PM
  3. Sword
    By Rory535i in forum 5 Series BMW
    Last Post: 04-12-2005, 09:59 AM
  4. took my sword out and nothing seems to be wrong
    By PABLO in forum 5 Series BMW
    Last Post: 09-12-2004, 04:56 PM
  5. I've got my sword out!
    By Bimmer Nut Ed in forum 5 Series BMW
    Last Post: 09-07-2004, 05:47 PM
Tags for this Thread
