LKM is a typical issue with these, commonly they can be taken apart and touched up with a bit of solder. I would link you to a walkthrough however I'm at work at the moment. Try googling "e34 lkm repair"
My drivers side lowbeam has gone out, I replaced the lamp, but should of checked voltage at the lamp first. I've got 11 volts at the lamp and 11 volts at the fuse. After reading through the threads, I should take a look at the LKM relays?
89 535I
89 volvo 240
78 Pontiac Trans Am, 6.6
1990 Islandgrun 535iM Sedan
3k oil changes | Euro lights + trim | Eibach/Bilstein | EAT Chip
Yip check LKM It's an easy fix
89 535 272,000km auto Euro
Got the boards out, brought it to work. I work at an electronics mfg company, and had one of the girls resolder the relays and touch up others. Had an engineer check it out, and , says it all looks good. Light still is out, and still 11 volts at the light and fuse. I've looked around for broken wires, and did find some copper strands comming out of the harness that leaves the little box that holds relays for the wiper wash system, on the drivers side of the fenderr, but my car doesn't have that feature. The passanger is getting 13 volts when the car is running.![]()
89 535I
89 volvo 240
It is either LKM, fuse or bulb... check ground strap by the faulty bulb side. Make sure ground is good.
I had a new bulb handy from the glove box, and put that in the passenger side to see if it worked and it did. Then I took the passenger light that was working and put it in the drivers side, and no light. Took out the bulb from the drivers side that I thought was bad, and works good in the pasenger side. If I hook the volt meter up and check the fuse for the drivers side it is 11, and the passenger is 13. Then I unplugged the light and tested the plug for the drivers side and it is 11, and no light. Also if, I unplugg the light I get a low beam warning message. I'm gonna have check the ground. I haven't tried swapping the fuses though.
89 535I
89 volvo 240
Ground and the contacts in the socket needs to be checked.
Alright! Got the headlight working again. Turns out if I wiggled the wire off the lamp by the grille, it would come on. I unwrapped the wires and wrapped them seperatley , and now I've got 13 volts. Now I need to figure out how come when I start the car, the interior light fuse blows.
89 535I
89 volvo 240
