What was the build date on the car it was installed in?
Sold!
1988 M3 - Track rat
1989 325iC
1995 530iM
2000 323iT - UUC BBK, PSS9 Coilovers
2005 GMC HD Crew
sold
1988 M3 - Track rat
1989 325iC
1995 530iM
2005 GMC HD Crew
Should be plug and play for anyone with an 11/94 or earlier build 530 then as I'm recalling that 12/94 was the start of EWS II use which would require the EWS codes to be synch'd with the chip after install.
GLWS, don't need it for my M-Sport though.
1988 M3 - Track rat
1989 325iC
1995 530iM
2005 GMC HD Crew
Dinan has the following info on their website:
E34 530
Performance Engine Chip
Dinan Performance Engine Chips unleash more power by re-programming the fuel mixture and ignition timing parameters of the engine management system. Furthermore the software safely raises the rev-limit, giving your BMW a broader power band and greater road speed potential in each gear. Significant gains are also achieved at part throttle, making extra power available where you spend the bulk of the time driving.
Part # Call Dinan
Labor Hours 0.8
Price $199.00
Emission Status 50 State Emissions Legal
Maximum Horsepower Gain 23 @ 6000 rpm
Maximum Torque Gain 23 lb/ft @ 3000 rpm
Point Value 2
Peak Horsepower 238 @ 6000 rpm
Peak Torque 228 lb/ft @ 4000 rpm
and the chip for the 540 E34
Part # Call Dinan
Labor Hours 0.8
Price $199.00
Maximum Horsepower Gain 15 @ 5500 rpm
Maximum Torque Gain 18 lb/ft @ 4000 rpm
Point Value 2
Peak Horsepower 296 @ 6000 rpm
Peak Torque 292 lb/ft @ 4500 rpm
http://www.dinancars.com/
