Originally Posted by
pundit
NOTE: Aftermarket remote/alarm fitted
* Central locking randomly locks/unlocks/ then locks again both when driving or with car parked and motor and ignition off and keys removed
Check your battery termincals are clean and that the battery is strong. Measure the alternator output, if it is dying it will cause 12V+/ reduced conditions that will upset things like this.
Check where the 'expert' who installed the alarm/remote locking made their mess and clean up the wiring. If not that, check the 50A fuse by the battery
NOTE: So far it has never unlocked by itself after being locked
* Cruise Control works intermittently If it drops out while cruising it will come back on again at the current set speed
Check your brake light switch for perfect continuity
* R/H Low Beam intermittent
HIDs from dtmtuning.com
* Transmission sports mode works intermittently
Console switch- beware coffee/coke etc.
Connector on the side of the trans.
Connector on trans cmputer module
* Car sometimes won't start (no cranking) but eventually does after 5-10 mins
Check your auto gear lever- the starter motor cutout switch is 'cutting out'
* Trip meter won't reset
Dirty/corroded contacts- twiddle it round a bit, it will start resetting.
* Rear wiper/washer n/w
LH tailgate wiring
NOTE: Left hand tailgate wiring looks cracked, I will fix this first and then see what the situation is.
