Results 1 to 2 of 2
Thread: M20 question
    Houston, TX
    Default M20 question
    The M20 on my '88 325 has an oil leak that I am pretty sure is a front cam seal that has gone toes up. How difficult is it to fix / replace the seal? Anybody have a procedure for that?
    Thanks.
    1995 530iA - 295,000 miles
    1988 325i convertible - 180,000 miles
    Sep 2007
    Michigan
    It's a pretty easy fix. You have to be sure the timing marks are lined up. I think Pelican and Bavauto have write ups on changing timing belts that will get you 95% of the way there. You should have a Bentley Manual. If you haven't changed the timing belt in the last 50,000 miles or 6 years you need to do that. Ask me how I know. You want to loosen the cam pulley bolts with the timing belt on. Water pumps need to be changed every 2 timing belts. Don't forget about the tensioner. You can see a write up on e30tech.com in the DIY section.
  1. Replies: 1
    Last Post: 11-06-2009, 07:35 PM
  2. Fuel filter question and bumper question
    By 1995 525i in forum 5 Series BMW
    Last Post: 08-26-2004, 08:22 AM
