Results 1 to 5 of 5
Thread: Control arm symptoms
    Mar 2011
    Appleton, WI
    Default Control arm symptoms
    What are some of the symptoms of worn lower control arm bushings? I've been reading some of the other posts and it seems that they may effect braking as well as vibrations while driving. I'm told that my lower bushings are bad, and I do get a slight vibration when braking, but nothing else. The car seems to run down the road fine at any speed.
    Car still on original lower control arm... should change it regardless. It is after all at least 16 years old! I think that's a pretty good lifetime for lower control arm.
    yeah how old are they?
    Mar 2011
    Appleton, WI
    Quote Originally Posted by BigKriss View Post
    I have no clue. I just bought the car. I'm probably the 8th or 9th owner. Seems like it's been pretty well cared for as the interior is close to immaculate. The body is in very nice shape too. It has about 280K kilometers on it. My guess is that they're probably the originals. Have a new pair so I may just change them tomorrow or next weekend. Was just wondering if that was the only issue or if it could be brakes too. I'll change the control arms and see what that does.
    Thanks.
    rarely the lower control arms bushes go bad. it could be the upper control arm bushes too (or the brakes too).
  1. Clogged Radiator Symptoms
    By rieosiris in forum 5 Series BMW
    Last Post: 08-22-2008, 09:45 PM
  2. Symptoms of a failing alternator?
    By JD525IA in forum 5 Series BMW
    Last Post: 06-06-2006, 09:45 AM
  3. Symptoms of Poor FPR
    By Gdub in forum 5 Series BMW
    Last Post: 10-01-2005, 12:45 AM
  4. Symptoms of a bad ABS module
    By xtmsports in forum 5 Series BMW
    Last Post: 04-16-2005, 06:14 AM
