Results 1 to 7 of 7
Thread: M50 fuel pressure question
    Default M50 fuel pressure question
    Recently been having some minor running issues, hunting idle and CEL etc.
    The fuel pump is noisy once running for a few minutes, so I checked the fuel pressure. With the FP relay jumped, its bang on 51-52 psi. With the engine running, it drops to ~43-44 psi. Bentley only states that the pressure drops when running, but what is acceptable?
    FWIW, I've purchased a new fuel pump and O2 sensor and they are due for replacement and relatively cheap (TRE performance pump - $60).
    As always, I greatly appreciate any and all input,
    Dave
    Oldham, England
    Fuel pressure drops about half a PSI for every inch of mercury of intake vacuum. So in theory you have an intake vacuum of 16 inches of mercury. IIRC a healthy engine is somewhere between 16 and 22 in Hg. That is good for up to 1000ft above sea level and from your location I think you are under that. If you are not at home you might need this chart:
    http://cts.rdhaglund.com/Impco/Large...OfAltOnVac.pdf
    FWIW I'm at about 800ft and get 51psi fuel pressure. With the engine running it drops to 42psi which tallies with my intake vacuum of 18 in Hg.
    Minneapolis, MN
    This discussion http://www.bimmernut.com/forum/5-ser...any-sense.html I had a few years ago might add some insight for you:
    I don't think my FPR was bad, but aged. I replaced it anyway in the end, which was nither a difficult nor expensive task.
    1995 525i 5-Speed 201,000mi
    Oldham, England
    Quote Originally Posted by BennyM View Post
    Nice to note I am at least consistent with my answers What sorted the problem in the end - O2 sensor, FPR or neither?
    Quote Originally Posted by whiskychaser View Post
    Thank you Whiskey and BennyM for the info. With regard to BennyM's old thread, I'm also interested in the culprit.
    I have replaced my FPR in the past few years, but likely still have the old one which was not suspect (just replaced as a precaution). I may try swapping it in if the new pump and or O2 don't solve my problems.
    Dave
    Minneapolis, MN
    A new O2 Sensor did the trick for me. In the process I had replaced several suspect vacuum hoses, the fpr, intake gaskets, and engine sensors, but O2 was the big one.
    Problem solved.
    After replacing a noisy fuel pump, FPR and much needed sending unit, I still had occasional hiccups and 1222/1212 codes. The morning of leaving on a 3,000km drive, I replaced the O2, which thankfully solved the problem and provided for a smooooooth drive and great mileage.
    Thanks again to all who responded with advice or experiences,
    Dave
  1. Replies: 8
    Last Post: 10-08-2007, 08:16 PM
  2. Fuel Pressure Testing Question
    By av8r in forum 5 Series BMW
    Last Post: 02-12-2007, 05:14 PM
  3. HELP! can't get fuel pressure regulator out of fuel rail....
    Last Post: 01-21-2007, 09:26 PM
  4. Replies: 4
    Last Post: 01-13-2007, 01:47 AM
  5. Question re: fuel pressure regulator
    By phildg2000 in forum 5 Series BMW
    Last Post: 07-06-2004, 07:56 PM
