Results 1 to 4 of 4
Thread: Sunroof question
    Mar 2011
    Appleton, WI
    Default Sunroof question
    Is the fabric for the headliner portion of the sunroof glued on after it folds around the inner sunroof panel, or is it clipped?
    Saw a thread talking about clips for it. The fabric on mine has fallen completely off the front edge of the inner panel. Trying to find out how it should be re-attached.
    Thanks.
    88 E30 325i Convert
    61,000 miles
    Cirrusblau
    it is glued at least on my E32, only clips are where the interior light is, see my website below under headliner repair.
    Here you can see the clips on the E34 Touring
    Roof trim-headlining moulded/handle BMW 5' E34, 525i (M50)
    Usually the 3mm foam in between the headliner material and the board just disintegrated and that causes the headliner to fall down.
    *DIY Headliners Replacement. - Bimmerforums - The Ultimate BMW Forum
    Mar 2011
    Appleton, WI
    What glue do you recommend? I assume that just a thin coat on the fabric will do the trick?
    88 E30 325i Convert
    61,000 miles
    Cirrusblau
    yes, but it must be clean and the old stuff has to be removed. In Germany you could buy
    KLEBER:
    Pattex Classic
    hochwärmefest, beständig bis 120°C
    http://www.klebeberater.de/index.php?id=3461
    they are specialized on headliners for older cars
    http://www.himmelservice.de/
  1. sunroof question
    By kyleN20 in forum 5 Series BMW
    Last Post: 06-24-2006, 05:06 AM
  2. Sunroof Shade Question??
    By rommel in forum 7 Series BMW
    Last Post: 10-17-2005, 03:28 PM
  3. Silly sunroof question
    By afxjzs in forum 5 Series BMW
    Last Post: 09-21-2005, 11:12 PM
  4. e30 sunroof motor conversion question????
    Last Post: 01-12-2005, 08:50 PM
  5. Sunroof Switch Question.....
    By George M in forum Electronics & Lights plus A/C
    Last Post: 07-12-2004, 02:33 PM
