Results 1 to 2 of 2
Thread: 1992 525i cooling system bleeding Help..!!!!
    Default 1992 525i cooling system bleeding Help..!!!!
    Hi, I hope all of you are doing well..!!! I have a Bmw 525i 1992 E34 with M50B25 engine, I´m having problems with the bleeding of my cooling system, Few days later after I do it, the coolant level goes down, and when I open the bleed screw, the level goes up again, and if I let him like that maybe in 2 weeks or less the car overheats!!.. what is happening?? please I need your help, I hope it is not a crack in the cylinder head or a little hole in head gasket, because I do not see any presence of milky oil..... thank You!!
    Possible that your hoses are stretching. Make sure you got the right collant cap too... should be flat and say 200 on it.
    I'd change your radiator hoses to be on safe side.
  1. Bleeding the E34 Cooling system
    By vping in forum 5 Series BMW
    Last Post: 07-17-2014, 10:50 PM
  2. Bleeding cooling system
    By gsreeves in forum 5 Series BMW
    Last Post: 01-21-2007, 03:18 PM
  3. Little help bleeding the cooling system
    By Jay 535i in forum 5 Series BMW
    Last Post: 07-04-2006, 01:25 PM
  4. Bleeding water system E34 525i M50
    By Busa1400 in forum 5 Series BMW
    Last Post: 05-10-2005, 09:12 AM
  5. M50-Bleeding the cooling system
    By John S Busby in forum 5 Series BMW
    Last Post: 12-19-2004, 12:12 PM
