Not sure... maybe the part guy who rips them off the junk cars simply used a cut off tool.
You probably would pay the same price if not lower if you buy rebuilt alternators from autohausAz or BMAparts... or Pelican.
So after 290,000km the original alternator went on old red. The car is a daily driver and the urgency of the situation called for the dreaded AutoZone replacement unit. The captured nut in the original unit's mounting lower rear tab was gone in the replacement. Went back to AZ and looked at several and they are all modified this way. Why would the rebuilder f*ck up the housings this way? Had to get a longer bolt and a nut to remount it. Leaves me feeling half assed and annoyed.
What the (heck) is the deal?
Link to my M50 engine rebuild thread
http://www.bimmernut.com/forum/showthread.php/43339-M50-Eng-4L30E-Trans-RRR-Far-More-Than-I-Ever-Expected?highlight=93+525+paul
Did they make you turn in the original as a core?
The brushes on your alternator (is/was it a bosch?) are ridculously easy to change, and might have fixed your problem.
I'd roll around on a 180k bosch 140a with replacement brushes, and not worry about nuffin'. Brushes are .50-1 at the appropriate store and the Regulator assembly can't be more than 60. If you still have the original consider popping new brushes in it and testing it at an auto parts store--i'd bet it would still be a perfectly serviceable spare.
Brushes are easy... but the bearing is what needs to be changed too especially if you got higher mileage. Spin the alternator and see if you can feel or hear bearings... you can tell if you got a new one... silky smooth... old one is kinda like rumbling and metal noises... metal on metal feel... meaning no grease left.
In case someone needs Hella voltage regulators for Bosch alternators, I still have some new on stock and they are in the swap meet - classified ads, 2 versions available, for 28 mm and 14/16mm diameter slip ring.
My out of town bro is using the car now and he did the R&R so I didn't get to look see. He asked if I wanted to keep the orig but I told him to turn it in...
