Results 1 to 4 of 4
Thread: Ratcheting Breaker Bar repair question
    Default Ratcheting Breaker Bar repair question
    I have a 1/2" Drive 18" Ratcheting Breaker Bar (3-way ratcheting action,right- and left-hand and locked), brand unkown, price was around $25 , so probably not best quality, but I use it quite often.
    I already had twice the experience that the left/right reversible ratcheting mechanics got stuck, either in one direction or completely = locked.
    Unfortunately it is not a brand tool and no lifetime warranty, so I would like to repair it.
    Typical description of such a tool is as reference only:
    This ratcheting breaker bar features left/right reversible ratcheting action for the torque of a breaker bar with the speed and convenience of a ratchet! The rugged ..-tooth ratchet locks in place for use as a traditional breaker and the ratchet head swivels 180 degrees.
    •Rugged 36 tooth ratchet locks in place for use as a traditional breaker
    •Left/right reversible ratcheting action
    •Ratchet head swivels 180 degrees
    Apparently the head locks always and cannot be turned left/right. Have already tried to spray some oil into the head thru the tiny clearance, once it worked again but now it is stuck.
    Has anybody ever disassembled such a head and repaired it? If so, how?
    How can it be diassembled?
    Can you post up a picture?
    Some of the inexpensive ratchets use a spiral locking ring to retain the ratcheting mechanism, unwind it and you'll be able to clean and lube it. On others there is a spring that pushes against the ball which positions the lever. Stretching the spring makes it less susceptible to popping out of position when a tough bolt breaks loose.
    Thanks for the info. It is Pittsburgh PRO CR-V
    Specifications
    Name 1/2" Drive 18" Ratcheting Breaker Bar
    SKU 67957
    Brand Pittsburgh Pro
    Certification ANSI
    Finish Chrome
    Material Vanadium Steel
    Swivel head Yes
    Drive size (in.) 1/2 in.
    Overall Length (in.) 18 in.
    It says Lifetime warranty, but for the $ 19.99 I bought it for, I even cannot ship it back to USA, so I want to repair it here, here is a pic
    Let me know how to disassemble it and I will do it. You mention some can be unwind: which direction, is that left or right hand thread?
    Nov 2013
    Brisbane, Australia
    Interesting, never seen a ratcheting breaker bar before Shogun. I would have thought it would be susceptible to locking up if you are using the sort of force that can be required to loosen a nut or bolt, where you'd normally use a conventional breaker bar for. It looks very similar in design to a Snap-On tool (which I use out of preference) but never seen or heard f a ratcheting one though.
    I paid $106 for mine though and its not a ratchet type, but very similar design handle wise.
    see the pic here..... GSN18B, Breaker Bar, 18"
    Specifications
    SKU 67957
    Certification ANSI
    Finish Chrome
    Swivel head Yes
  1. Bought me one of them there breaker-bars...
    Last Post: 06-25-2007, 09:40 PM
  2. Repair caliper kit question
    Last Post: 06-01-2006, 09:28 AM
  3. OT - Air compressor keeps tripping circuit breaker
    By Dave Rutkowski in forum 5 Series BMW
    Last Post: 02-16-2006, 01:57 PM
  4. Arm Rest Repair Question
    By Jimmy535i in forum 5 Series BMW
    Last Post: 10-25-2004, 05:30 PM
