HowTo: make you own fan clutch tool for M60
For removing the visco clutch fan you normally need a 32mm open wrench as long as possible, and the holder for the pulley. While it is easy to make such a holder for the M30 and the M70 as the bolts on the pulley stick nicely out, you need some bushes for the M60 as the pulley has a different design, as on this the bolts do not stick out so much. Here the drawing
http://www.e32-schrauber.de/bmw/date...schluessel.png
the tool finished
http://www.e32-schrauber.de/bmw/date...e/P1000340.jpg
In case you have the standard holder and you cannot get a grip on the M60 pulley on the screws with your tool, remove 2 bolts, add some thick washers onto the bolts and screw them in again, then the tool will also fit.
Here you can see the pulley and details with another method in Timm's BMW E31 840i M60 Water Pump/Viscous Fan Replacement
BMW E31 840ci M60 Water Pump and Viscous Fan Replacement
