Results 1 to 3 of 3
Thread: negative battery cable
    Jul 2004
    New Haven, CT
    Default negative battery cable
    1995 525, the clamp is cracked, still holding but curious about changing it, anybody know where the other end is? Meaning the end that goes to ground, not clear looking around the battery itself,
    John
    Where is your battery located? Engine bay or under right hand side rear seat? E34 have batteries in engine bay or under rear seat.
    If under rear seat, there is a plastic cover in front of the seat base, remove that plastic cover, there you will find the end of the battery ground cable
    https://www.youtube.com/watch?v=Dcv3WrlnLvE
    Jul 2004
    New Haven, CT
    Thanks Shogun, rear seat is where mine is located, I'll check for the plastic cover you are speaking about,
    Thanks for your assistance,
    John
  1. Negative camber in the rain
    By ahlem in forum 5 Series BMW
    Last Post: 10-22-2012, 08:59 AM
  2. Routing a power cable from battery to boot
    By Shando in forum 5 Series BMW
    Last Post: 07-05-2007, 08:54 AM
  3. Got negative camber???
    By RickyBobby in forum 5 Series BMW
    Last Post: 02-27-2006, 10:34 PM
  4. E34 '95 negative battery terminal
    By spaceboyo in forum 5 Series BMW
    Last Post: 02-26-2005, 10:13 AM
