Hi,
Normally this means low oil level ""Check Engine Oil Level"". Might be the low level sensor playing up if that is you have oil in the sump
HTH
Steve
I actually get the message in German and it translates to "Owner's Handbook". Why would this message appear on the CC? What does it mean?
I actually get two Priority 3 messages, the other is "Sensor Oelstand" which I believe means the oil pressure sensor is defective. Where do I find this sensor?
Philip
Hi,
HTH
Steve
mine says "coolant level, See Owner's Manual" and it also does that after the engine oil low and coolant temp
but only the oil level one is true. But yours is in German, thats so cool for some reason...
Change the display back to english, reset your codes and see what it does after that.
