Results 1 to 10 of 14
Thread: where is the fusible link ? - photos
    Aug 2008
    Default where is the fusible link ? - photos
    Here are some photos of the fusible links in my '89 525i.
    My car has an m20 engine and the battery is located in the engine compartment. (and the driver sits on the left)
    There is an 80 amp fuse located near the passenger side front shock tower.
    It broke when I moved it a tiny bit, all of a sudden the car was completely dead, in the rain at night. Easy fix, though.
    There is a 50 amp fuse under the rear seat, near the connector (which can also break).
    Mine looked to be in good shape but I replaced it anyway.
    There are some good pics of a fusible link in an e32 here. I believe most e34s have the battery under the rear seat (where my cd changer is), so the location is probably a little different, but it's there, somewhere!
    Maryland, Virginia, D.C.
    Nice one Tim Eh.
    open
    http://farm3.static.flickr.com/2264/...a3621cdc_b.jpg
    closed
    http://farm3.static.flickr.com/2156/...5ec40ba518.jpg
    pics from the German E34 forum. Cooments there:
    für den E34 mit Batterie unter der Rückbank gibt es insgesamt 3 verschiedene Sicherungshalter.
    - eine mit einem Eingang und einem Ausgang.
    - eine mit einem Eingang, einem gesicherten Ausgang und einem ungesicherten Ausgang
    - eine mit einem Eingang, 2 gesicherten Ausgängen und einem ungesicherten Ausgang.
    Letzte Variante sieht dann so aus.
    short translation:
    for the E34 with battery under the rear seat there are in total 3 different designs of fuse holders:
    -one with one In and OUT connection
    -one with one IN and a fused OUT connection and a non-fused OUT
    -one with one IN , 2 fused OUT connections and one non-fused out connection, this one is shown in the pics.
    Aug 2008
    here is a pic of the ungesicherten ausgang i removed from the sicherungshalter.
    Quote Originally Posted by ThoreauHD View Post
    Nice one Tim Eh.
    ...timeh
    Gee Tim, did you fix your electrical gremlin or are you gonna shoot for episode XX?
    Aug 2008
    http://www.bimmernut.com/forum/showthread.php?t=39967
    Woah!
    Nice write up. The link in the front, once it is insulated, where does it sit? I've never seen one located on the tower before. Did you pull it up/out form somewhere?
    Fusible links are always close to the battery, so in front close to the shock mounts only in case the battery is in the engine bay, otherwise all is under rear seat next to the battery.
    http://www.bmwe34.net/E34main/Mainte...sible_link.htm
    Ah I see, they both go inside the plastic housing... back with the program the program now .
  1. fusible link - am i missing something?
    By 525i winter driver in forum 5 Series BMW
    Last Post: 08-17-2008, 04:56 PM
  2. Missing Fusible Link?
    By Happy_Go_Lucky in forum 5 Series BMW
    Last Post: 09-20-2006, 08:06 AM
  3. Question About Fusible Link......
    By Dave M in forum 5 Series BMW
    Last Post: 06-01-2006, 02:55 PM
  4. Fusible Link Question
    By doogie in forum 5 Series BMW
    Last Post: 02-24-2005, 04:23 PM
  5. Fusible link or bad battery?
    By rickm in forum 5 Series BMW
    Last Post: 01-01-2005, 12:20 PM
