there should be a wire to connect that keeps a bit of power to the deck so it remembers the presets. check in your manual for you deck and see what color the wire on in your deck harness and then on the e34 website theres a wiring diagram and tells you what color the wire is in the bmw harness. i remember when i installed my clarion, i had the same problem. good luck
Originally Posted by Incantation
