Results 1 to 5 of 5
Thread: Found the reason for overheating problem
    Macomb, MI
    Default Found the reason for overheating problem
    The neck of the bleed screw on the expansion tank was cracked. Along with the o-ring being bad, all kinds of air was getting into the system. Tried a couple of things to try and repait it with no luck. I did not want to drop the funds into a new radiator right now. Finally, I went to the hardware store and got a small hose clamp and some heavy duty plastic epoxy. Put on the epoxy and tightened down the hoe clamp till the crack was seamless. Let it sit overnight and bled the system. Drove all the way to work today without a drop of coolant leaking (knock on wood). The wife is not happy, as I just put new tires on the car. The upkeep issues may cause me to get rid of her soon.
    Bloomsbury, NJ
    Default "...The upkeep issues may cause me to get rid of her soon...".
    ...you are referring to your wife, right?? ;-) Sorry, I couldn't resist!!
    Congrats on your temporary fix...they can be a PITA in maintenance, but damn are they fun to have around (the wife AND the car!)
    Tim G.
    '91 535iM
    Quote Originally Posted by Abnormal
    Macomb, MI
    Default Good come back! Want to buy a wife?
    Quote Originally Posted by TimGinCentralNJ
    Tim G.
    '91 535iM
    Mar 2004
    BTW, the bleed screw is available separately, it's PN 17 11 1 712 888 and many models use the same part.
    Paul Shovestul
    Macomb, MI
    Default Thanks, but it was the neck that cracked on the radiator itself.
    Quote Originally Posted by Bellicose Right Winger
    Paul Shovestul
  1. overheating problem
    By innes in forum 5 Series BMW
    Last Post: 09-22-2006, 06:28 PM
  2. Overheating problem!!
    By JAK in forum 5 Series BMW
    Last Post: 08-05-2006, 07:57 AM
  3. overheating problem
    By E34maystar in forum 5 Series BMW
    Last Post: 02-01-2006, 01:29 PM
  4. M50 non vanos overheating problem
    By Bruno in forum 5 Series BMW
    Last Post: 09-13-2004, 07:27 PM
  5. Another overheating problem
    By sah525i in forum 5 Series BMW
    Last Post: 08-29-2004, 07:18 PM
