I took a VERY small screwdriver and bent the tip about 1/2" back 90 degrees. There are two detents left and right at the front. If you go in at about 1.5 inches from each side, you should hit it about right. Lift one side slightly, then lift the other. You'll feel it come up. At the rear are only slides to hold it down, but the detents are at the front. I've had mine out several times, once to replace the slider, and others to just clean it all up. Spilled Cokes will make it harder to lift up. A little Son of a Gun under the wood, where it lays in, and it will be easier to get up next time (joke in there somewhere...)Originally Posted by ScottyWM
Good luck,
Bill B.(sweatin' over here west of 55!)
