the tighter you put the lash the less vaccum at idle, if you have a good idle then I'd try it at .011 and see if the chatter goes away. If it doesn't then you know that there is something wrong in there.
Too much ticking, I'm not sure if it's a damaged valve or what, but I'm gonna open up the cover, check for damage from the spray bar incident, and tighten em down a bit. Bentley says .014 hot, .012 cold... I'm going to do at least .012, does anybody run .011? Any performance/idle issues? My idle is fine on this car, minimal vaccum leaks, new cap/rotor, fresh O2 sensor.
i like to do my valve adjustments with it as hot as i can stand it, i do a lot more m20's then anything else, those are .10 cold .12 hot i like .11 hot, i haven't really worked up a custom m30 setting
When this happens to me Tim I find that it's usually my technique. I now do all the valves twice and each time doublecheck the gap with the next size up gauge. I find that about 1/2 the time after the first "adjust attempt" I can get the next size up feeler in. Whoops.
Jeff
Bellevue WA
86 Porsche 951 - Track Toy
Agree with Jeff...very easy to make a mistake. I try to check mine twice as well. My big six sounds pretty good at a slip .013" cold for intake and exhaust which is probably similar to .012" hot which Winfred likes.
George
Set it to a tight .011 dead cold, and all the valve noise is gone. Not quite as responsive or sensitive, but it's quiet enough so I can hear that unnerving bottom-end noise... gotta love those 200k+ motors!
Originally Posted by TC535i
