At 205K, you could go another 100K or a lot more before needing rebuild. You need to be sure the coolant has been changed regulary, and of course the oil. If the car has a generally good (and known) maintenance history, 205K is nothing to fret over. If there are no records and no signs of routine maintenance, I would shy away from it.
Originally Posted by Unregistered
