Results 1 to 4 of 4
Thread: Which factory alarms are plug'n'play
    Default Which factory alarms are plug'n'play
    I want to get the factory alarm, just so I have keyless entry. I'm not too worried about security because it's pretty safe around here, but keyless entry would be handy. I want the factory one so I can just plug it straight in with no worries. I have a 11/89 buil 525i, and I found a green plug near the fusebox under the back seat that I assume is for the keyless module. When looking through the wreckers, which cars have a compatible units??? Are all E34 alarms compatible, how about E32?
    Windy City
    Default Two different types for E34.
    I’ve seen two different harness types for E34. Both were OEM BMW by Alpine but more connectors in harness for newer Alpine alarms (newer E34). You should check the connector type first as they look completely different.
    Picture below is the OLDER harness type for E34 and E32. My 1995 E34 harness looks nothing like this one.
    RICK
    BMW 1995 525i (Alpine White)
    Nashville, TN
    Was there something available for 88-92 ? Everything I have seen is for 92 and later cars. On an FAQ someone mentioned hacking into the driver's footwell, is this correct ? Is it a plug ? bare wires ?
    Derek A.
    90 535i 5 Speed - Style 5 17"
    I had my RHD Drivers side underneath-of-dash apart a while back, and that connector looks familiar. There were quite a few blank connectors in there, I'm sure one looked like that. The text mentions that sometimes the connector is the passengers footwell, perhaps on RHD cars it's the drivers one???
    Last time I was under the back seat there was a green connector with a small plastic bag over the end. It had more than 12 pins though, looked like a computer data cable or something. Wonder what that's for...
  1. Anti-Theft System (DWA) false alarms
    Last Post: 03-01-2009, 10:41 PM
  2. FS: Factory amp
    Last Post: 04-03-2007, 08:15 AM
  3. Pin Out For factory Amplifier e34?
    By attack eagle in forum 5 Series BMW
    Last Post: 02-11-2007, 06:49 PM
  4. BMW Factory Alarm
    By Steve Walker in forum 5 Series BMW
    Last Post: 09-24-2006, 03:52 AM
  5. E34 factory options?
    By pundit in forum 5 Series BMW
    Last Post: 03-18-2005, 04:13 AM
