Results 1 to 4 of 4
Thread: E34 540i/6 Strange Noise
    Jul 2004
    Default E34 540i/6 Strange Noise
    First time I've posted to this board, though I've lurked around for a few months. I was hoping to take advantage of everyone's knowledge and experience and make my life easier.
    I have a '95 540i/6, 117,000 miles. I bought it back in September of '03, and unfortunately had to replace the clutch about a month later. While I was in there, I replaced the flywheel, exhaust hardware, seals, driveshaft center bearing, flexdisc, etc.
    Over the past 2-3 days I've had a noise coming from the rear of the car, from what seems to be the center. The best way I can describe it is a regular, consistant "flipping" noise - kind of like sticking a card in the spokes of an old bicycle when you were a kid. Definitely sounds as if something that is rotating is hitting or rubbing at the same point every rotation. I won't have a chance to get the car in the garage to look at it until this weekend, but here's what I've noticed thus far:
    -The sound is only noticable at low speeds, and the slower the speed the more noticable. The frequency of the "flip" decreases with speed.
    -It happens in any gear, including neutral.
    -Occurs under breaking as well as coasting.
    -The sound completely disappears when throttle is applied, even the slightest bit.
    -Doesn't appear to occur in reverse.
    Not a whole lot of information I know. I was suspecting a warped brake rotor perhaps, but the sound is the same when breaking and not.
    If anyone has any ideas or clues I'd really appreciate it.
    Thanks in advance,
    -Matt
    Kingston, Ontario, Canada
    Hmmmm...could be the CV joints of the final drive (either of the two rear half-shafts connecting the differential output to the rear wheels.) This could be the equivalent of a FWD car with the ticking sound when worn CV joints are combined with large steering inputs...
    Just an idea...mein2¢
    Cheers,
    Duey
    1995 540i/6 Sport Pkg w/E.A.T. chip and Nikasil injection Duey's Gallery
    Or depending on the type of wheels, it could be a loose center cap or wheel cover.
    Melbourne (Australia)
    Could also be a fault in one of the rear tyres causing the tread to bulge.
    Reid (530iA)
  1. Strange Noise
    By GAM in forum 5 Series BMW
    Last Post: 10-03-2006, 08:27 PM
  2. Strange noise while accelerating
    By Matias in forum 5 Series BMW
    Last Post: 07-28-2005, 08:44 AM
  3. Strange Noise Between 2,300 - 2,800 RPM
    By sandhaven9 in forum 3 Series BMW
    Last Post: 07-21-2005, 11:25 PM
  4. M30 engine - strange bearing noise
    By simon-york in forum 5 Series BMW
    Last Post: 02-18-2005, 12:41 PM
  5. Strange noise under the dash
    By Will308 in forum 5 Series BMW
    Last Post: 10-08-2004, 04:33 AM
