ECU maps & AFM voltage and MAF conversions (long)
OK - here's a summary of some stuff that I've been trying to muse through as I ponder the effect of the MAF conversion on my setup. I think these are trueisms....challenge as you wish. Posted for interest and to stimulate thought.
All related to the M30 setup.
1 - the AFM has a voltage range of basically 0 to 5 volts. The output voltage is based on the angle of the flapper door.
2 - the AFM flapper door goes to a maximum angle before before the engine reaches maximum RPM. Exact point is not 100% clear - I've heard suggestions that this occurs at about 3000 to 3500 RPM at WOT. Never tested it though. I have no clue at what point, if ever, the AFM reaches max flapper angle at anything less than WOT.
3 - The ECU selects the correct fuel map (mid map vs WOT map) based on the TPS. If the TPS stays WOT, then the ECU ignores the AFM flapper and bases fuel and advance on the engine RPM only.
4 - If the TPS has not signaled WOT, then the mid map is used and the fuel and advance settings are a function of the engine RPM and the flapper door angle. The flapper door angle is basically synonomous with the "load" on engine. This is sent to the ECU as voltage between 0 and 5 volts.
5 - A MAF sensor replacing the AFM has the ability to "process" more air flow than the AFM. This means that a MAF can measure more air passing thru the unit before it is maxed out.
6 - When either a MAF or AFM is maxed out, it will send 5 volts to the ECU.
7 - For a MAF kit to correctly "work" in the 535 the following must be true. For a given amount of airflow, the output voltage of the MAF must be the same as the output voltage of the AFM. If the MAF sends less voltage for a given amount of air, the ECU assumes less load and the mixture will tend to be lean. If the MAF sends more voltage, the ECU assumes more load and the mixture will tend to be rich. Timing will also be effected.
8 - The MAFs ability to spoof the ECU via changing the "load" (voltage) gives you a basic ability to "tune" your mixture. However, this "tune" only changes the relative lookup in the WOT and Mid throttle maps. The map profile contained in the chip is not modified or effected.
Sooo...there seem to be a couple of interesting thoughts or questions - assuming this is more or less true.
a - tuning your mixture by modifying the voltage output of the MAF relative to airflow can have unintended consequences on the timing. The more you spoof the ECU on the airflow, the more likely you are to have an unintended timing change.
b - it's likely better to modify the fuel and ignition maps to be correct for your (modified) engine and do only very nominal fine tuning via the MAF.
c - The best MAF setting is as close to a 1 to 1 relationship as you can get with the AFM. The only way to calibrate your MAF voltage to the AFM voltage is to compare the two on a flowbench. (BTW, this is done for you with a base 535 voltage curve with the Racing King MAF).
d - I think - At less than WOT on the TPS, the AFM flapper must not ever reach max angle. At not WOT on the TPS, you are running the mid range map and you need two inputs to locate the correct fuel and timing value - load and RPM. If the flapper reaches max angle while the engine conditions are still changing, there is no way for the ECU to measure and adjust mixture and timing. The purpose of the WOT map, which determines values ONLY based on RPM, is to account for the flapper door going to max angle.
BTW - I really like the MAF kit on my car. There's no question the car runs better. I'm just trying to get my arms around what tinkering with the voltage table in the control box really does.
Hmmm...ok. That's enough for now. Thoughts?
Jeff
Bellevue WA
86 Porsche 951 - Track Toy
