Originally Posted by
Robert K
These are brand new plugs Bill. Now that you mention it, I'm not sure I really had this problem before installing the new plugs. I believe I checked to make certain they were the correct part number for my car. At first, I installed them with the factory .028 gap. But then I rememebered everyone suggesting a wider gap, so I opened the gap to .033. What should I be checking in regards to the plugs??? It did suprise me when you stated that ignition problems show up at light throttle, but it makes sense.
I'll check the crank sensor, but it should be okay since I removed it to tighten the crank sensor bracket bolts a few months back when I thought they might be causing my oil leak. I snugged all those bolts up pretty good, but I'll check again anyway.
Also, what does one check with the plug wires? Or for that matter the cap and rotor. I did remove the cap and rotor when this all started. I looked at the contacts and also washed both with dishwashing soap and then dried with a hairdryer before reinstalling. I didn't notice any cracks or carbon trails. As I mentioned, the plug wires are originals. Whether they are the actual problem or not, I probably just need to break down and replace them. With the long runs they have being parallel to each other inside the plastic cover, I'm sure it's very easy for them to leak.
As far as the O2 sensor, it probably is time. I'm at 130,000 and I changed it last around 60,000. I just hate to change parts in an attempt to luck into finding the problem, you know what I mean? On a BMW, that can get expensive.
Thanks for the reply. All additional info is always greatly appreciated.
Grace and peace,
Robert K
1991 535i
