valve seating surfaces clean.
Originally Posted by Hector
I installed new rocker arms and shafts, and clean the springs and washers. Everything is lubed. Now one thing that happens is that the shafts will slide out a bit from the pressure of the springs: the exhaust shafts slide toward the front of the head the the intake shafts slide toward the rear. I have to use some head bolts to stop them from sliding out more.
http://www.geocities.com/frothlikn/classic_tan13.html
As a result, the exhaust rocker arm excentrics are slightly off center from the valve tip as reference by the red line.
http://www.geocities.com/frothlikn/classic_tan14.html
and so are the intake rocker arm excentrics.
http://www.geocities.com/frothlikn/classic_tan15.html
Both sides seem to be off from center tip by 20 to 30 mils. Is this normal?
Thought I screwed up/forgot to assembly something somewhere. Thanks again.
Good info from Bill on that score. Hector be sure to loctite the rocker shaft end plugs in place. Couldn't find a torque spec for those..but they are not very tight. The plugs retain oil pressure to lubricate the rocker arms up through the hollow shafts.
George
Very ingenious to have the excentric slightly off center from the valve tip/stem to allow the valves to rotate to clean the seats. Bill, you could've easily become a brain surgeon...
