cant you try westerns HD software? It has an option to write zeros to the drive and you start with a brand new blank unformatted drive, might be what you need to clean the sectors up.
its moving week here in kollege town, and as a result, i've managed to net two perfectly fine (300mhz and 550 mhz with trifiling problems) PCs from the "display" area next to the dumpster (also got a REALLLYYY nice monitor that accompanied the 500) at my apartment. i had a 30 gb hard drive that i had on a p133 motherboard (running a 233 chip), that obviously needed the maxtor overlay to work on aforementioned motherboard. i previously installed w98 and w2k on it. when i put it in, it will get to the point where it asks me which op sys i'd like to start, at which point in w2k it will show the splash screen for about 30 secs, and then say something to the effect of "error reading I/O device" . it will act similarly in w98. I tried manually typing in the heads/cylinders into the bios, which let it run for a little bit longer before it halts. i tried using the latest maxtor software to try to take the overlay off, but there's no option in it for doing that. any suggestions? tia.
Great dumpster diving, Ryan!
Reformat the hard drive and start clean. You'll have to reinstall Windows.
Ramon
1994 540iA Nikasil EAT Chip
Tampa Bay, Florida USA
fdisk /mbr then run delpart.exe on it. WD has their wddiag software (self booting floppy) that will allow you to check the drive for bad sectors and (maybe) mark them as such.
you can hang around my dumpster, I have 49 monitors, 35 PCs and 22 printers that I need to dispose of before Tuesday morning. :P
Originally Posted by rickm
Can't. Nothing the State owns can be ebay'd. I'm about to go in and inventory each item then submit the list for state surplus. That will buy me some time. The fun part was running the 10x wipe on each hard drive to make sure they contain no data. B-o-r-i-n-g. Then I get to do this at 2 other facilities.
i will do what you ask...i need a clean 8 ounce glass, and some milk, and i'll make them all disappear
1.. it wasn't "dumpster diving" i only get things 266 mhz and above. there's so much good stuff thrown away here at move out time, that some hatians with an old f250 come by every sunday afternoon (this month) and look for mattresses and furniture that has been retroactively thrown away (when they change the style of the apartment furnishings). everything i've ever gotten from over there has somehow ended up in the hands of one of my friends (ie, their monitor dies, stereo, vcr, et cetera)...they like to talk crap about me doing it, but they aren't reluctant to accept it from me when they need it. in this case, i could see across the parking lot that a very expensive monitor was sitting beside the dumpster (put there so someone would take it away without having to muck about in the trash). the 550 computer went along with it. all i had to do was unplug a bum seagate 20 gb hdd from it, and put in a old power supply i had laying around, and it functioned perfectly. the 333 mhz pentium II is going into my mom's computer (its 300 right now, dell mobo only goes up to 333), and i'll throw the rest of it away.
2. i wanted to keep the data on it, i might just stick a 4 gb unit on there with w2k and use it to explore the 30 gb one until i make sure that all of my important stuff is off of it. i was hoping that maxtor had a way to take off the overlay without format, i guess that isn't to be.
Im not really sure what you're doing, because I didn't read the whole post, but if you still need help when I get up to skool, let me know, I've got all kinds of utlities for HDDs. I desperately need some new hard drives and memory from trash PCs to put together these old shells of computers I have sitting in my office and put them to some use.
Originally Posted by ryan roopnarine
it lets you drop an IDE drive in a USB box and put it on a good system, thatll let you do all kinds of stuff to it
I have a PII 350 mhz processor that I will trade you for the 300mhz one.
I know this sounds really dumb, but its those wacky bus speeds and I don't feel like typing now. I'll explain tomorrow at work.
