Results 1 to 4 of 4
Thread: idle problems
    Aug 2004
    Default idle problems
    People
    I have a uk spec 520 se touring, 24 valve, recently noticed the idle goes up and down between 0-3000 rpm, there has been info on this site that it maybe the IVC needs cleaning so where is the IVC on a 520, any info muchly appreiciated.
    Jib
    Aug 2004
    Quote Originally Posted by jib
    People
    I have a uk spec 520 se touring, 24 valve, recently noticed the idle goes up and down between 0-3000 rpm, there has been info on this site that it maybe the TVC needs cleaning so where is the TVC on a 520, any info muchly appreiciated.
    Jib
    Jul 2004
    You might also check Air Flow Meter - when mine was bad I had idle problems too.
    But my car engine is M20
    baton rouge, loserana
    look for air leaks, just did one the other day that the hose from the valve cover to the airboot was rotted off causing idle problems
  1. Idle problems... help!
    By halogen25 in forum 5 Series BMW
    Last Post: 12-23-2006, 07:43 PM
  2. So you are having some idle problems?
    By shrike071 in forum 5 Series BMW
    Last Post: 12-05-2006, 03:14 AM
  3. Idle Problems
    By Riry Jetta in forum 3 Series BMW
    Last Post: 05-11-2006, 08:25 AM
  4. idle problems (again)
    By panzershreck in forum 5 Series BMW
    Last Post: 07-17-2004, 10:05 PM
  5. Having Problems With A Rough Idle
    By SIXPACKDREAMER in forum 5 Series BMW
    Last Post: 03-11-2004, 03:02 PM
