Results 1 to 3 of 3
Thread: Soft swaybar bushing broken
    Minnesota
    Default Soft swaybar bushing broken
    I have a '89 325iC that has a broken bracket for the front driver's side sway bar bushing. After obtaining a new bracket and getting under the car I realized that the crossmember attachment is what was broken. I have no place to connect the bracket! Has anyone had this problem, is it a matter of fabricating and welding an attachment piece to the crossmember or do I have to replace that whole front cross member?
    Aug 2004
    BILLINGS, MONTANA-LOT'S OF TWISTIES FOR THE WEEKENDS
    I Was Successful In Welding/reinforcing The Rear Sway Bar Mounts On The Rear Control Arms, Have Not Lost The Front. Looks Like You Or Someone You Know Will Have To Assess Which Of Your Only Two Options Is The Best Route. I Know Welding Saved Me An Even More Undesirable Headache, And I Was Able To (maybe Excessively) Reinforce The Problem Area. All I Hear Is That All Mounting Points For E30 Sway Bars,(f+r), Weaken And Break When Oversized Bars Are Installed. Especially If Your Suspension Setup Is Stiff.
    Minnesota
    Thanks for the response, looks like I'll be talking to someone about welding this thing. I don't even know if replacement front crossmembers are available.
  1. stock swaybar link aftermarket swaybar
    Last Post: 07-20-2010, 03:28 AM
  2. Soft On/Off Interior Light Retrofit
    By Jr ///M5 in forum 5 Series BMW
    Last Post: 11-25-2008, 09:44 PM
  3. Clutch Pedal is WAAAAYYYYY too soft.
    By icesoft in forum 5 Series BMW
    Last Post: 04-30-2007, 08:50 PM
  4. Replaced front swaybar and front swaybar links
    Last Post: 03-14-2005, 09:16 AM
  5. Broken thrust arm bushing: Can they cause alignment problems?
    By Badshift in forum Stuff over a year old
    Last Post: 02-05-2004, 10:54 AM
